Grafana Cloud 12.1.0-91295 - What are you trying to achieve?
Create a new InluxDB Data Source. - How are you trying to achieve it?
Copy/paste the configuration from another InfluxDB Data source created in Grafana cloud 11. - What happened?
Not able to connect to DB, with errors:
“There was an error when testing this data source, please check PDC agent logs.”
“InfluxDB returned error: Unauthorized error reading influxDB”
PDC logs shows that it is connected:
Jul 17 19:46:30 grafanagw pdc[3325]: level=info caller=ssh.go:304 ts=2025-07-17T19:46:30.184877031Z msg=“debug1: channel 1: connected to drm-librenms.cec.delllabs.net port 8086”
Same as the original Data Source (created with Grafana 11), when “Save & test” get the connections working and retrive data: “datasource is working. 160 measurements found” -
N/A -
Yes, we get an error:
InfluxDB returned error: Unauthorized error reading influxDB” -
Did you follow any online instructions? If so, what is the URL?No
thanks!
Ruben
