lorawan
December 4, 2023, 10:00am
1
10.2.2
Add data source from influxdb
On the web interface
I entered the credentials of my grafana in the Basic Auth Details
I entered the credentials of my influxdb in the Basic Auth Details
What happened?
Error. I checked systemctl status grafana-server and it says “Error performing influxdb healthcheck”
How should I continue troubleshooting?
kistk
December 5, 2023, 1:46pm
2
i have same problem.
Grafana/Influxdb run as docker on synology.
Both are in a new Network named Docker “bridge”
Most Tutorials use old Version, with Database Name, Bucket …
In the LOG: Connection refused
Someone a solution? : )
BR K
i also could not get it to work with credentials for some reason
the only method it would connect is if i use token from influx , the one displayed on initial setup
and also only with the flux query language
grant2
September 9, 2024, 9:02pm
4
Welcome @leondavibe and @kistk
If you want InfluxQL, you can try following the steps that I posted here:
