I’m trying to run grafana behind a reverse proxy (ngnix), I’m following the guide and have the following:
server {
listen 443 ssl;
server_name grafana.example.com;
root /usr/share/nginx/html;
index index.html index.htm;
# ! SSL config here
# Your location blocks and proxy settings for Grafana go here
location / {
proxy_set_header Host grafana.example.com;
proxy_pass http://grafana;
# Proxy Grafana Live WebSocket connections.
location /api/live/ {
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
proxy_set_header Host $http_host;
and the following in the grafana config:
[server]
# Protocol (http, https, h2, socket)
;protocol = http
# This is the minimum TLS version allowed. By default, this value is empty. Accepted values are: TLS1.2, TLS1.3. If nothing is set TLS1.2 would be taken
;min_tls_version = ""
# The ip address to bind to, empty will bind to all interfaces
;http_addr =
# The http port to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = grafana.example.com
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = http://grafana.example.com
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
serve_from_sub_path = false
When trying to access grafana.example.com, I get ‘Bad Request (Invalid Host)’.
Could anyone tell me what I’m doing wrong?
