Results detailed output
Hello everyone, is there any possibility in K6 to export a detailed report after each run which includes all the errors with status codes, all requests with response times (90th, 95th)etc…something similar to Jmeter HTML report? Thanks in advance
Hi @AG1337 !
Welcome to the community forums! :wave:
For sure, it’s possible :relaxed: There are a couple of ways to do that, but for instance, if you’re looking for just HTML output, you can use the k6’s extension GitHub - benc-uk/k6-reporter: Output K6 test run results as formatted & easy to read HTML reports.
Let me know if that helps,
Cheers!
Hi @olegbespalov,
In my opinion, AG1337 means results like JMeter HTML report with details charts for ex these is the parameters that contain JMeter HTML report:
Statistics:
  • [x] Excections → Fail, Error%
  • [ ] AVG
  • [x] Min
  • [x] Max
  • [x] Mean
  • [ ] Median
  • [x] 90th pct
  • [x] 95th pct
  • [x] 99th pct
  • [ ] Transactions/s
  • [x] Network(Data Recived)
  • [x] Network(Data Sent)
Over Time
  • [x] Response Times Over Time(AVG response in ms)
  • [ ] Response Time Percentiles Over Time (successful responses)(Response time in ms)
  • [ ] (90th percentile, 95th percentile, 99th percentile, Max Med, Min)
  • [ ] 90th percentile
  • [ ] 95th percentile
  • [ ] 99th percentile
  • [x] Max
  • [ ] Median(Middle)
  • [x] Mean
  • [x] Min
  • [x] Active Threads Over Time(without filter)
  • [ ] Bytes Throughput Over Time(Bytes / sec)
  • [ ] Latencies Over Time(AVG response latency in ms)
  • [ ] Connect Time Over Time(AVG connect time in ms)
Throughput
  • [ ] Hits Per Second
  • [ ] Error Codes Per Second
  • [ ] Transactions Per Second → Request name (URLs)
  • [ ] Total Transactions Per Second
  • Transaction-success
  • Transaction-failure
  • [ ] Response Time Vs Request → Failures/Successes
  • [ ] Latency Vs Request → Failures/Successes
ResponseTimes
  • [ ] Response Time Percentiles → Request name (URLs)
  • [ ] Response Time Overview
  • Requests having response time <= 500ms
  • Requests having response time > 1,500ms
  • Requests having response time > 500ms and <= 1,500ms
  • Requests in error
  • [ ] Time Vs Threads
  • [ ] Response Time Distribution
Could you please write a script that exports the data from CSV or JSON and appear it on the HTML details reports with the charts?
Hi @fuadqpros !
If the need is to make the graphics in the result HTML sure, the suggested reporter won’t fit since it works on the aggregated result.
And as far as I know, no output produces static HTML reports with graphics. But you could output the metrics to the CSV to JSON and create your custom static visualization (and here I can’t help you) on top of that.
However, the effort in creating such a thing could be higher than just using a different approach for the visualization Ways to visualize k6 results.
Cheers!
Thanks for this idea @olegbespalov :star_struck:
That’s helpful :ok_hand:
