Restrict data on graph panel by some nodes only
Hi all,
I’m newbie and hope you’ll be able to help.
I have a graph panel which shows number of records in logs from some nodes.
But I need to limit set of nodes to view this number only from part of them, i.e. from nodes with hostname ends by es-master-data
Hope to get advice soon.
Thanks,
Alexander
Hi @alexanderkaptsanov, welcome to the community!
Depending on your use case you can write your query to show only those nodes. If you want to create a more dynamic filter, you can also use template variables.
You can see an example of a dashboard with template variables here.
To see how they’re used for the example dashboard, click on the gear icon (dashboard settings) and then click on variables.
