Using variables in the nodegraph panel
    Using Grafana 10.2.2
    I am trying to create a panel of a dashboard with the nodegraph panel to display a selected servicegraph similar to the servicegraph displayed in Tempo. The filter option doesn’t accept variables. The aim is to use service.name as a variable to constrain how much of the ServiceGraph to display when selecting a service.name via a variable.
    I added a NodeGraph Panel and examined the filter option.
  • What happened?
    Variables are not accepted in the nodegraph filter therefore results are blank.
That said the data in the Tempo ServiceGraph is driven from the ServiceGraph Metrics derives from the OTEL ServiceGraph Metrics Processor. Has anyone created a similar input to the NodeGraph dynamically ?
    Would be good if the filter accepted variable names.
    There are no errors but it is clear that variables are not accepted in the filter option for the NodeGraph panel as it is for other panel types.
    Node graph | Grafana documentation
hi, did you try this: How can I try Datagrid visualization? - #7 by ebabeshko
You need to activated the [feature_toggles] enable = transformationsVariableSupport.
That’s helps me, to use variables in transformations…
Self Solved.
The nodegraph chart does use variables, i had to use the client = $ServiceName and server=$ServiceName and it stuck.
The variable doesn’t show up in the list in the filter but was accepted and worked.
