I’m currently using netdata to monitor metrics and performance on my nodes in real time. I’ve yet to find anything that tops it for real time measurements.
I’m moving all our stack monitoring and metrics to grafana dashboards. I want to bring netdata realtime dashboards into that. Thanks to netdata custom html templates, and the grafana Text panel I can create this holy love child of the two.
What I want is this: I want to be able to run a query that lists the nodes in my stack filtered by a property, then for each node in the list show a Text panel that has my netdata dashboard in it, passing in the node as a template parameter to inject into the text panel.
I KNOW RIGHT?! Crazy COOL!
Is it even possible?
Yours hopefully,
ndtreviv
svetb
May 20, 2021, 2:33pm
2
Hi @nathan3547 ! I think it should be possible. I’m not familiar with netdata though. Are you able to create a Grafana template variable that contains the list of nodes? Once you’ve done that you can set up your text panel to repeat for each value of that variable (and use the variable in the HTML).
So I was hoping to get the list of nodes via a query against a datasource in grafana - still possible?
Also, I can’t see in the Text panel how to pass variables in… I’m still very much learning
I’ve worked out how to create dashboard variables. The problem is I’m struggling with the query. The values I want to get come from an elasticsearch datasource, but they’re not store-d, so I can’t create a query to target them.
I can create a table panel that lists them by choosing Raw Data as the metric and applying a couple of transformations, being:
Filter by Name (host.name)
Group By (host.name)
This gives me a set of hostnames from my .monitoring-es-* indices.
I then want those to be the variable values, but I can’t see how to do that in the dashboard Variables query section.
Is this possible, or do I need to change metricbeat to specifically index the hostname as a separate field?
svetb
May 20, 2021, 3:58pm
5
Thanks for following up! It’s good that you can query the node list via the ElasticSearch datasource. I’m afraid I know very little about that datasource though, so can’t really help with getting the right set of variable values - hopefully someone else on here can. To prompt better responses, maybe you could share some screenshots of what your queries/responses look like.
And indeed, the variable queries lack the comprehensive “slicing and dicing” capabilities that you can use in panels…but hopefully you can get to where you need to.
In the panel itself, you should be able to use $varname inside your HTML, which will interpolate to each of the variable values.
Ok, I figured it out.
First of all I had to modify my filebeat config to include the hostname as a searchable, aggregatable field, then create a new dashboard with a dashboard variable that targeted that field.
Then I created a Text panel with the following content:
<script
type="text/javascript"
src="http://${Nodes}:19999/dashboard.js"
></script>
<div class="netdata-chart-row">
<div
class="netdata-container-easypiechart"
style="margin-right: 10px; width: 11%; will-change: transform"
data-host="http://${Nodes}:19999"
data-netdata="system.io"
data-dimensions="in"
data-chart-library="easypiechart"
data-title="Disk Read"
data-width="11%"
data-before="0"
data-after="-360"
data-points="360"
data-common-units="system.io.mainhead"
role="application"
<div
class="netdata-message icon hidden"
style="font-size: 11.9px; padding-top: 51.05px"
<svg
class="svg-inline--fa fa-chart-area fa-w-16"
aria-hidden="true"
data-fa-processed=""
data-prefix="fas"
data-icon="chart-area"
role="img"
xmlns="http://www.w3.org/2000/svg"
viewBox="0 0 512 512"
<path
fill="currentColor"
d="M500 384c6.6 0 12 5.4 12 12v40c0 6.6-5.4 12-12 12H12c-6.6 0-12-5.4-12-12V76c0-6.6 5.4-12 12-12h40c6.6 0 12 5.4 12 12v308h436zM372.7 159.5L288 216l-85.3-113.7c-5.1-6.8-15.5-6.3-19.9 1L96 248v104h384l-89.9-187.8c-3.2-6.5-11.4-8.7-17.4-4.7z"
></path></svg
><!-- <i class="fas fa-chart-area"></i> -->
netdata<span style="position: absolute; opacity: 0; width: 0px"
>system.io</span
</div>
<div
id="easypiechart-b87170f8-0e7a-27fd-9190-81b5377baf35-chart"
class="netdata-chart netdata-easypiechart-chart"
style=""
<span class="easyPieChartLabel" style="font-size: 15px; top: 51px"
>0.1</span
><span
class="easyPieChartTitle"
style="font-size: 8px; line-height: 8px; top: 32px"
>Disk Read</span
><span class="easyPieChartUnits" style="font-size: 7px; top: 76px"
>MiB/s</span
><canvas
height="238"
width="238"
style="height: 119px; width: 119px"
></canvas>
</div>
</div>
<div
data-dimensions="out"
data-title="Disk Write"
data-width="11%"
data-before="0"
data-after="-360"
data-points="360"
role="application"
<div
style="font-size: 12px; padding-top: 51px"
<svg
aria-hidden="true"
data-prefix="fas"
role="img"
<path
fill="currentColor"
></path></svg
>system.io</span
</div>
<div
id="easypiechart-f21f266c-8098-75f2-8ab1-b141b5737dd5-chart"
style=""
<span class="easyPieChartLabel" style="font-size: 16px; top: 51px"
>0.2</span
><span
style="font-size: 9px; line-height: 9px; top: 30px"
>Disk Write</span
><span class="easyPieChartUnits" style="font-size: 8px; top: 78px"
>MiB/s</span
><canvas
height="240"
width="240"
style="height: 120px; width: 120px"
></canvas>
</div>
</div>
<div
class="netdata-container-gauge"
style="margin-right: 10px; width: 20%; will-change: transform"
data-netdata="system.cpu"
data-chart-library="gauge"
data-title="CPU"
data-units="%"
data-gauge-max-value="100"
data-width="20%"
data-after="-360"
data-points="360"
data-colors="#22AA99"
role="application"
<div
style="font-size: 21.7px; padding-top: 51.65px"
<svg
aria-hidden="true"
data-prefix="fas"
role="img"
<path
fill="currentColor"
></path></svg
>system.cpu</span
</div>
<div
id="gauge-0d05677f-6e04-6d1b-bbb0-9e3b77f46f8d-chart"
class="netdata-chart netdata-gauge-chart"
style=""
<canvas
id="gauge-0d05677f-6e04-6d1b-bbb0-9e3b77f46f8d-canvas"
class="gaugeChart"
width="434"
height="260"
style="width: 217px; height: 130px"
></canvas
><span class="gaugeChartLabel" style="font-size: 26px; top: 33px"
>1.0</span
><span
class="gaugeChartTitle"
style="font-size: 12px; line-height: 12px; top: 0px"
>CPU</span
><span class="gaugeChartUnits" style="font-size: 11px">%</span
><span class="gaugeChartMin" style="font-size: 20px">0.0</span
><span class="gaugeChartMax" style="font-size: 20px">100.0</span>
</div>
</div>
<div
data-netdata="system.net"
data-dimensions="received"
data-title="Net Inbound"
data-width="11%"
data-before="0"
data-after="-360"
data-points="360"
data-common-units="system.net.mainhead"
role="application"
<div
<svg
aria-hidden="true"
data-prefix="fas"
role="img"
<path
fill="currentColor"
></path></svg
>system.net</span
</div>
<div
id="easypiechart-952883a8-b560-bee7-715f-49438b44ce39-chart"
style=""
>0.5</span
><span
>Net Inbound</span
>megabits/s</span
><canvas
height="240"
width="240"
></canvas>
</div>
</div>
<div
data-dimensions="sent"
data-title="Net Outbound"
data-width="11%"
data-before="0"
data-after="-360"
data-points="360"
role="application"
<div
<svg
aria-hidden="true"
data-prefix="fas"
role="img"
<path
fill="currentColor"
></path></svg
>system.net</span
</div>
<div
id="easypiechart-c7b79f11-6959-1335-9716-a6a05da05e56-chart"
style=""
>0.5</span
><span
>Net Outbound</span
>megabits/s</span
><canvas
height="238"
width="238"
></canvas>
</div>
</div>
<div
style="margin-right: 10px; width: 9%; will-change: transform"
data-netdata="system.ram"
data-dimensions="used|buffers|active|wired"
data-append-options="percentage"
data-title="Used RAM"
data-units="%"
data-easypiechart-max-value="100"
data-width="9%"
data-after="-360"
data-points="360"
data-colors="#EE9911"
role="application"
<div
style="font-size: 9.8px; padding-top: 41.1px"
<svg
aria-hidden="true"
data-prefix="fas"
role="img"
<path
fill="currentColor"
></path></svg
>system.ram</span
</div>
<div
id="easypiechart-34ec531c-54bb-ad66-5d01-484e7a26f2fb-chart"
style=""
<span class="easyPieChartLabel" style="font-size: 13px; top: 41px"
>58.7</span
><span
style="font-size: 7px; line-height: 7px; top: 25px"
>Used RAM</span
><span class="easyPieChartUnits" style="font-size: 6px; top: 62px">%</span
><canvas
height="196"
width="196"
style="height: 98px; width: 98px"
></canvas>
</div>
</div>
</div>
and repeat the panel based on the nodes dashboard variable.
The panels don’t always render nicely the first time, and sometimes require a refresh - I’m still figuring this out.
