REST API - syntax of a dashboards filter
I try query Grafana 4.2.0 for available dashboards using HTTP API.
I can do it for all but when I try use ‘query’ to take only dashboards what starts from “PR” I didn’t receive results.
Can you provide me correct syntax for this or any link when can I find a syntax description?
Yes, I read http://docs.grafana.org/http_api/dashboard/
Thank you in advance.
There is nothing special with the syntax here - just a query string parameter. Here is an example from my local Grafana:
http://grafana.staged-by-discourse.com/api/search?query=PR
In my case it matched a few dashboards with Prometheus in the title.
Thank you. Yes, it works. Yesterday I probably missed ‘?’.
