Hi there,
I am trying to display a pipeline on a Grafana dashboard.
At the moment I am using a separate Single Stat visualization to represent each stage of the pipeline.
The stage metric returns 0 if it hasn’t run yet and 1 if it has completed - so using thresholds the visualizations light up green as they finish.
I am just wondering if there is a better option to display this info?
The advantage of Single Stat is that I can manually arrange each visualization in the order that the pipeline runs, and I’m not sure if any of the other visualizations will give me that option.
I am using Grafana v9.5.1 - any suggestions are much appreciated ![]()
