I am trying to use the Reporting feature in Grafana Cloud, but one of the issues I have run into is that I can not select every template variable for a single report. I have pannels for 10 variables I’d like to show all within the same report. Is there a way to do this whether it’s using APIs to make my own report or a plugin?
Hi @ecombs1 !
Can you clarify if the dashboard variables do not display as a selectable option when creating a new report?
For example, the datasource, job, region, etc variables that are populated here:
