Repeat Panel with "include all" variable shows not data
I’m trying to create a repeating panel showing some graph for every value of my “instance” variable. As soon as a enable the “Include all” option for the variable every panel just shows “No data in response” instead of my graph. When disabling “Include all” it works at least for individually selected instances but I would like to have it repeating for every instance…
Grafana v8.1.1 (90c87a52f7)
I want my panel to repeat for every value of a variable.
See dashboard JSON below.
  • What happened?
The panel repeats but it says “No data in response” in every panel.
Panel should repeat showing a graph for every value of the instance variable.
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": "-- Grafana --",
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "editable": true,
  "gnetId": null,
  "graphTooltip": 0,
  "id": 165,
  "iteration": 1628752444905,
  "links": [],
  "panels": [
      "datasource": null,
      "fieldConfig": {
        "defaults": {
          "color": {
            "mode": "palette-classic"
          "custom": {
            "axisLabel": "",
            "axisPlacement": "auto",
            "barAlignment": 0,
            "drawStyle": "line",
            "fillOpacity": 0,
            "gradientMode": "none",
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineInterpolation": "linear",
            "lineWidth": 1,
            "pointSize": 5,
            "scaleDistribution": {
              "type": "linear"
            "showPoints": "auto",
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
            "thresholdsStyle": {
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
        "overrides": []
      "gridPos": {
        "h": 9,
        "w": 8,
        "x": 0,
        "y": 0
      "id": 2,
      "options": {
        "legend": {
          "calcs": [],
          "displayMode": "list",
          "placement": "bottom"
        "tooltip": {
          "mode": "single"
      "repeat": "instance",
      "repeatDirection": "h",
      "targets": [
          "exemplar": true,
          "expr": "windows_os_visible_memory_bytes{instance=\"$instance\"}",
          "interval": "",
          "legendFormat": "",
          "refId": "A"
      "title": "Panel Title",
      "type": "timeseries"
  "schemaVersion": 30,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": [
        "allValue": null,
        "current": {
          "selected": false,
          "text": "All",
          "value": "$__all"
        "datasource": null,
        "definition": "label_values(windows_os_visible_memory_bytes, instance)",
        "description": null,
        "error": null,
        "hide": 0,
        "includeAll": true,
        "label": null,
        "multi": false,
        "name": "instance",
        "options": [],
        "query": {
          "query": "label_values(windows_os_visible_memory_bytes, instance)",
          "refId": "StandardVariableQuery"
        "refresh": 1,
        "regex": "",
        "skipUrlSync": false,
        "sort": 0,
        "type": "query"
  "time": {
    "from": "now-6h",
    "to": "now"
  "timepicker": {},
  "timezone": "",
  "title": "test",
  "uid": "3dNBK6Mnz",
  "version": 1
It just says “No data in response” for every panel.
@michaelcc35
Is this the behavior you want? I copied your JSON, changed the query to one that would work on my test instance, and then fiddled a tad with your variable config. See link to vid and the json here:
  "annotations": {
    "list": [
        "builtIn": 1,
        "enable": true,
        "hide": true,
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "editable": true,
  "gnetId": null,
  "graphTooltip": 0,
  "id": 1,
  "iteration": 1630607177767,
  "links": [],
  "panels": [
      "datasource": null,
      "fieldConfig": {
        "defaults": {
          "color": {
          "custom": {
            "axisLabel": "",
            "barAlignment": 0,
            "fillOpacity": 0,
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineWidth": 1,
            "pointSize": 5,
              "type": "linear"
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
        "overrides": []
      "gridPos": {
        "h": 9,
        "w": 8,
        "x": 0,
        "y": 0
      "id": 2,
      "options": {
        "legend": {
          "calcs": [],
        "tooltip": {
          "mode": "single"
      "targets": [
          "exemplar": true,
          "expr": "up{}",
          "interval": "",
          "legendFormat": "",
          "refId": "A"
  "style": "dark",
  "tags": [],
  "templating": {
    "list": [
        "allValue": null,
        "current": {
          "selected": true,
          "text": [
            "All"
          "value": [
            "$__all"
        "datasource": null,
        "definition": "up{}",
        "error": null,
        "hide": 0,
        "includeAll": true,
        "label": null,
        "multi": true,
        "name": "instance",
        "options": [],
        "query": {
          "query": "up{}",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "type": "query"
  "time": {
    "from": "now-6h",
    "to": "now"
  "timepicker": {},
  "timezone": "",
  "title": "test",
  "uid": "yUlcBE47k",
  "version": 3
