Rendering failed
im running Grafana v6.3.4 on my Raspberry Pi 4 and need help to render an image.
I installed phantomJS with this tutorial (https://community.openhab.org/t/tutorial-grafana-rendering-on-raspberry-pi/71777) on my Raspberry but im still getting the error “Rendering failed” if i click on “Direct link rendered image”.
Here is the log:
t=2019-09-01T13:06:03+0200 lvl=info msg=“Registering plugin” logger=plugins name=“Backend Renderer”
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing HooksService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing LoginService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing SearchService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing TracingService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-09-01T13:06:03+0200 lvl=info msg=“Renderer plugin found, starting” logger=rendering cmd=plugin_start_linux_arm
t=2019-09-01T13:06:03+0200 lvl=info msg=“Initializing Stream Manager”
t=2019-09-01T13:06:03+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
t=2019-09-01T13:06:03+0200 lvl=eror msg=“Rendering failed.” logger=context userId=1 orgId=1 uname=admin error=“No renderer found”
t=2019-09-01T13:06:03+0200 lvl=eror msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/render/d-solo/nISKbEZRk/raumklima status=500 remote_addr=192.168.178.63 time_ms=7 size=1722 referer=“http://192.168.178.85:3000/d/nISKbEZRk/raumklima?orgId=1&refresh=1m
t=2019-09-01T13:06:05+0200 lvl=eror msg=“Stopped RenderingService” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped Stream Manager”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped TracingService” logger=server reason=nil
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-09-01T13:06:05+0200 lvl=info msg=“Stopped HTTPServer” logger=server reason=nil
t=2019-09-01T13:06:05+0200 lvl=eror msg=“Server shutdown” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Starting Grafana” logger=server version=6.3.4 commit=a557646 branch=HEAD compiled=2019-08-19T16:28:51+0200
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2019-09-01T13:06:06+0200 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2019-09-01T13:06:06+0200 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2019-09-01T13:06:06+0200 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2019-09-01T13:06:06+0200 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2019-09-01T13:06:06+0200 lvl=info msg=“App mode production” logger=settings
t=2019-09-01T13:06:06+0200 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=4776
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2019-09-01T13:06:06+0200 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing RemoteCache” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing QuotaService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing PluginManager” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Starting plugin search” logger=plugins
t=2019-09-01T13:06:06+0200 lvl=info msg=“Registering plugin” logger=plugins name=“Backend Renderer”
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing HooksService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing LoginService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing SearchService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing TracingService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-09-01T13:06:06+0200 lvl=info msg=“Renderer plugin found, starting” logger=rendering cmd=plugin_start_linux_arm
t=2019-09-01T13:06:06+0200 lvl=info msg=“Initializing Stream Manager”
t=2019-09-01T13:06:06+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
t=2019-09-01T13:06:08+0200 lvl=eror msg=“Stopped RenderingService” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped Stream Manager”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped TracingService” logger=server reason=nil
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2019-09-01T13:06:08+0200 lvl=info msg=“Stopped HTTPServer” logger=server reason=nil
t=2019-09-01T13:06:08+0200 lvl=eror msg=“Server shutdown” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Starting Grafana” logger=server version=6.3.4 commit=a557646 branch=HEAD compiled=2019-08-19T16:28:51+0200
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2019-09-01T13:06:09+0200 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2019-09-01T13:06:09+0200 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2019-09-01T13:06:09+0200 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2019-09-01T13:06:09+0200 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2019-09-01T13:06:09+0200 lvl=info msg=“App mode production” logger=settings
t=2019-09-01T13:06:09+0200 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=4824
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2019-09-01T13:06:09+0200 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing RemoteCache” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing QuotaService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing PluginManager” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Starting plugin search” logger=plugins
t=2019-09-01T13:06:09+0200 lvl=info msg=“Registering plugin” logger=plugins name=“Backend Renderer”
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing HooksService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing LoginService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing SearchService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing TracingService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-09-01T13:06:09+0200 lvl=info msg=“Renderer plugin found, starting” logger=rendering cmd=plugin_start_linux_arm
t=2019-09-01T13:06:09+0200 lvl=info msg=“Initializing Stream Manager”
t=2019-09-01T13:06:09+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
t=2019-09-01T13:06:11+0200 lvl=eror msg=“Stopped RenderingService” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped Stream Manager”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped TracingService” logger=server reason=nil
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2019-09-01T13:06:11+0200 lvl=info msg=“Stopped HTTPServer” logger=server reason=nil
t=2019-09-01T13:06:11+0200 lvl=eror msg=“Server shutdown” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Starting Grafana” logger=server version=6.3.4 commit=a557646 branch=HEAD compiled=2019-08-19T16:28:51+0200
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2019-09-01T13:06:12+0200 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2019-09-01T13:06:12+0200 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2019-09-01T13:06:12+0200 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2019-09-01T13:06:12+0200 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2019-09-01T13:06:12+0200 lvl=info msg=“App mode production” logger=settings
t=2019-09-01T13:06:12+0200 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=4947
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2019-09-01T13:06:12+0200 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing RemoteCache” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing QuotaService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing PluginManager” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Starting plugin search” logger=plugins
t=2019-09-01T13:06:12+0200 lvl=info msg=“Registering plugin” logger=plugins name=“Backend Renderer”
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing HooksService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing LoginService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing SearchService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing TracingService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-09-01T13:06:12+0200 lvl=info msg=“Renderer plugin found, starting” logger=rendering cmd=plugin_start_linux_arm
t=2019-09-01T13:06:12+0200 lvl=info msg=“Initializing Stream Manager”
t=2019-09-01T13:06:12+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
t=2019-09-01T13:06:14+0200 lvl=eror msg=“Stopped RenderingService” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped TracingService” logger=server reason=nil
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped Stream Manager”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-09-01T13:06:14+0200 lvl=info msg=“Stopped HTTPServer” logger=server reason=nil
t=2019-09-01T13:06:14+0200 lvl=eror msg=“Server shutdown” logger=server reason=“Unrecognized remote plugin message: \n\nThis usually means that the plugin is either invalid or simply\nneeds to be recompiled to support the latest protocol.”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Starting Grafana” logger=server version=6.3.4 commit=a557646 branch=HEAD compiled=2019-08-19T16:28:51+0200
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config loaded from” logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config loaded from” logger=settings file=/etc/grafana/grafana.ini
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.data=/var/lib/grafana”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.logs=/var/log/grafana”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.plugins=/var/lib/grafana/plugins”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Config overridden from command line” logger=settings arg=“default.paths.provisioning=/etc/grafana/provisioning”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Path Home” logger=settings path=/usr/share/grafana
t=2019-09-01T13:06:15+0200 lvl=info msg=“Path Data” logger=settings path=/var/lib/grafana
t=2019-09-01T13:06:15+0200 lvl=info msg=“Path Logs” logger=settings path=/var/log/grafana
t=2019-09-01T13:06:15+0200 lvl=info msg=“Path Plugins” logger=settings path=/var/lib/grafana/plugins
t=2019-09-01T13:06:15+0200 lvl=info msg=“Path Provisioning” logger=settings path=/etc/grafana/provisioning
t=2019-09-01T13:06:15+0200 lvl=info msg=“App mode production” logger=settings
t=2019-09-01T13:06:15+0200 lvl=info msg=“Writing PID file” logger=server path=/var/run/grafana/grafana-server.pid pid=4993
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2019-09-01T13:06:15+0200 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing RemoteCache” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing QuotaService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing PluginManager” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Starting plugin search” logger=plugins
t=2019-09-01T13:06:15+0200 lvl=info msg=“Registering plugin” logger=plugins name=“Backend Renderer”
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing HooksService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing LoginService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing SearchService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing TracingService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-09-01T13:06:15+0200 lvl=info msg=“Renderer plugin found, starting” logger=rendering cmd=plugin_start_linux_arm
t=2019-09-01T13:06:15+0200 lvl=info msg=“Initializing Stream Manager”
t=2019-09-01T13:06:15+0200 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
I hope somebody can help me.
png rendering is not supported on ARM
So there is no possibility to use the render function on my raspberry pi?
Dont think there is. Found your thread as my thread was heading the same way.
Rendering on RPI : SITE
