$ sudo grafana-cli plugins install grafana-image-renderer
Error: ✗ grafana-image-renderer v is not supported on your system (Grafana v9.2.4 linux-arm64)
If any alternative options to install in same processor.
Hi @prabhu5992,
Welcome to the
community support forums !!
This is actually a known issue for image-render-plugin which can be viewed at:
Currently it is still open as need more RnD work but there are some workaround/alternatives posted by other users which has helped others.
