Is there any way to clip the first and / or last data points from a time series / table?
I’m querying data from InfluxDB via FlightSQL / Arrow SQL and aggregating period host stats by clusters of hosts. As each host is reporting at a different point in the reporting interval, it’s often the case that the first and last intervals, which has already been time boxed from the grafana time boundaries, do not contain a data point for every host in the cluster, meaning when we add up their, say, total memory usage, it often drops off massively at each end, making a graph useless.
Anyway to clear up this data in SQL or through a Transformation or such to only have the middle 99% of data points or something?
No, I didn’t find a solution yet. merely shifting the time window does not resolve this as it’s about removing the last block of results, not a rolling window, which just shifts the same problem back by one time interval.
