Remove Welcome to Grafana panel from homepage
Stupid question maybe, but I’m not able to remove the Welcome to grafana and Latest from blog panel from my Grafana home page.
Can remove the panels, save the dashboard but after opening the page again they are back again.
Got those panels after updating from Grafana 6 to 7.
You can set your own Home dashboard and set this dashboard in Configuration->Preferences->Home Dashboard.
Keep in mind that your newly created dashboard must be starred in order to be saved as Home dashboard.
Did you find a solution to this?
Thanks
James
