I’m using Grafana v10.2.2
How can I remove a specific app named Ansys from the dashboard?
Wherever I’m in the settings, it’s impossible to find a way to remove it ![]()
thanks for your help!
click on the gear and find the variable named App generating the data. what does it show?
thanks for guiding me.
You mean this gear in the top right corner?
if yes, and I do this … then JSON model?
if yes, there is no Ansys included
click on variables on left menu
thank you very much! Will look into it
