Once a filter is created, I am unable to remove it by pressing the ‘X’ icon. We did not see a menu.
What kind of filter are you creating? How are you creating it?
Marcus
First i use only the plus sign inside the data Table.
Next, i try a adhoc filter on the graylog datasource.
i think this problem occure fits after our update our graylog from 2.x to 5.x…
Please make sure that you’re using version v5 in the datasource configuration of elasticsearch.
Please let me know if this works
Marcus
Yes this is my configuration
Thanks. I’m not sure where you mean you press the “X” icon. But if you click on source drop down right to the adhoc label in the upper corner of your screenshot you should find a –remove filter. Does that help you?
Marcus
angular.js:12759 GET https://grafana.gh.de/api/datasources/proxy/16/graylog_/mapping 404 (Not Found)
(anonymous) @ angular.js:12759
g @ angular.js:12492
u @ angular.js:12244
u @ angular.js:17051
(anonymous) @ angular.js:17095
$digest @ angular.js:18233
(anonymous) @ angular.js:18462
i @ angular.js:6362
(anonymous) @ angular.js:6642
setTimeout (async)
c.defer @ angular.js:6640
$evalAsync @ angular.js:18460
(anonymous) @ angular.js:16923
c @ angular.js:17095
f @ angular.js:17122
h @ angular.js:17106
resolve @ angular.js:17001
(anonymous) @ datasource_srv.js:101
Promise resolved (async)
loadDatasource @ datasource_srv.js:85
get @ datasource_srv.js:73
t.testDatasource @ ds_edit_ctrl.ts:163
(anonymous) @ ds_edit_ctrl.ts:194
$apply @ angular.js:18531
(anonymous) @ angular.js:18832
i @ angular.js:6362
setTimeout (async)
M @ angular.js:18831
$applyAsync @ angular.js:18563
u @ angular.js:12544
v @ angular.js:12785
k.onload @ angular.js:12702
XMLHttpRequest.send (async)
i @ angular.js:6362
setTimeout (async)
(anonymous) @ angular.js:27346
dispatch @ jquery.js:5206
g.handle @ jquery.js:5014
datasource.ts:258 {data: {…}, status: 404, config: {…}, statusText: “Not Found”, headers: ƒ, …}config: data: undefinedheaders: Accept: "application/json, text/plain, /"X-Grafana-NoCache: "true"X-Grafana-Org-Id: 1__proto_: constructor: ƒ Object()arguments: (…)assign: ƒ assign()caller: (…)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, hasOwnProperty: ƒ, isPrototypeOf: ƒ, propertyIsEnumerable: ƒ, toString: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()proto: ƒ ()[[FunctionLocation]]: hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()defineGetter: ƒ defineGetter()defineSetter: ƒ defineSetter()lookupGetter: ƒ lookupGetter()lookupSetter: ƒ lookupSetter()get proto: ƒ proto()set proto: ƒ proto()jsonpCallbackParam: "callback"method: "GET"paramSerializer: ƒ (e)arguments: (…)caller: (…)length: 1name: ""prototype: {constructor: ƒ}proto: ƒ ()[[FunctionLocation]]: angular.js:11207[[Scopes]]: Scopes[2]retry: 0transformRequest: Array(1)0: ƒ (e)length: 1__proto__: Array(0)transformResponse: Array(1)0: ƒ Ft(e,t)length: 1__proto__: Array(0)url: "api/datasources/proxy/16/graylog_/mapping"proto: constructor: ƒ Object()arguments: (…)assign: ƒ assign()caller: (…)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, hasOwnProperty: ƒ, isPrototypeOf: ƒ, propertyIsEnumerable: ƒ, toString: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()proto: ƒ ()[[FunctionLocation]]: hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()defineGetter: ƒ defineGetter()defineSetter: ƒ defineSetter()lookupGetter: ƒ lookupGetter()lookupSetter: ƒ lookupSetter()get proto: ƒ proto()set proto: ƒ proto()data: error: index: "grafana"index_uuid: "na"reason: "no such index"resource.id: "grafana"resource.type: "index_or_alias"root_cause: Array(1)0: index: "grafana"index_uuid: "na"reason: "no such index"resource.id: "grafana"resource.type: "index_or_alias"type: "index_not_found_exception"proto: Objectlength: 1__proto_: Array(0)concat: ƒ concat()constructor: ƒ Array()copyWithin: ƒ copyWithin()entries: ƒ entries()every: ƒ every()fill: ƒ fill()filter: ƒ filter()find: ƒ find()findIndex: ƒ findIndex()flatMap: ƒ flatMap()flatten: ƒ flatten()forEach: ƒ forEach()includes: ƒ includes()indexOf: ƒ indexOf()join: ƒ join()keys: ƒ keys()lastIndexOf: ƒ lastIndexOf()length: 0map: ƒ map()pop: ƒ pop()push: ƒ push()reduce: ƒ reduce()reduceRight: ƒ reduceRight()reverse: ƒ reverse()shift: ƒ shift()slice: ƒ slice()some: ƒ some()sort: ƒ sort()splice: ƒ splice()toLocaleString: ƒ toLocaleString()toString: ƒ toString()unshift: ƒ unshift()values: ƒ values()Symbol(Symbol.iterator): ƒ values()Symbol(Symbol.unscopables): {copyWithin: true, entries: true, fill: true, find: true, findIndex: true, …}proto: Objecttype: "index_not_found_exception"proto: Objectstatus: 404__proto__: Objectheaders: ƒ (n)status: 404statusText: "Not Found"xhrStatus: "complete"proto: constructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()defineGetter: ƒ defineGetter()defineSetter: ƒ defineSetter()lookupGetter: ƒ lookupGetter()lookupSetter: ƒ lookupSetter()get proto: ƒ proto()set proto: ƒ proto()
BUT – The datasource is working. I can see all elastic* messages from this datasource. I can filter the Messages and so one… (See my first picture).
I am Sure that the menue is funtional with our 2.x Elastic Datasource
Please verify that your indexed are named graylog_*. Maybe they was renamed when you upgraded graylog.
Marcus
Ok, it works! it was a security Problem against our Graylog Server.
After a successfully request we see the index Files and the remove Filter.
Thanks
Great that you got it working!
Have a nice day
Marcus
