Hello all, we already have configured our loki and remote promtail.
Both of the localhost promtail and remote promtail are working and sending updated logs through HTTP. However we need to send encrypted logs over the internet.
When using HTTPS on URL in promtail, we are receiving
level=error ts=2022-02-16T17:59:34.281444845Z caller=client.go:360 component=client host=loki-server.domain:9200 msg="final error sending batch" status=404 error="server returned HTTP status 404 Not Found (404): 404 page not found" -
Our loki port 3100 is running @ proxy port of 9200.
This is the status of curl command from our remote host
HTTP/2 200
server: nginx
date: Wed, 16 Feb 2022 17:50:54 GMT
content-type: application/json
content-length: 58
{"status":"success","data":["__name__","filename","job"]}
- Configuration of our promtail both localhost and remote
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: 'https://username:key@loki-server.domain:9200/loki/api/v1/push/'
scrape_configs:
- job_name: remote-nginx
static_configs:
- targets:
- localhost
labels:
job: remote-nginx-logs
__path__: /var/www/*/log/*.log
- Config file of our loki
server:
http_listen_port: 3100
http_listen_address: 127.0.0.1
http_server_read_timeout: 1000s
http_server_write_timeout: 1000s
http_server_idle_timeout: 1000s
log_level: info
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
Thanks!
