v10 -
Sending the logs via Grafana Agent to Promtail and then to Loki -
Install and configre grafana agent on Linux server with sending logs to http://promtail:9089/api/v1/prom
Promtail already configure and pointing to Loki -
What happened?
msg=“final error sending batch” status=404 tenant= error=“server returned HTTP status 404 Not Found (404): 404 page not found” -
Expect transfer the logs to Loki -
Blockquote
Grafana agent
integrations:
node_exporter:
enabled: true
# disable unused collectors
disable_collectors:
- ipvs #high cardinality on kubelet
- btrfs
- infiniband
- xfs
- zfs
# exclude dynamic interfaces
netclass_ignored_devices: “^(veth.|cali.|[a-f0-9]{15})$”
netdev_device_exclude: “^(veth.|cali.|[a-f0-9]{15})$”
# disable tmpfs
filesystem_fs_types_exclude: “^(autofs|binfmt_misc|bpf|cgroup2?|configfs|debugfs|devpts|devtmpfs|tmpfs|fusectl|hugetlbfs|iso9660|mqueue|nsfs|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|selinuxfs|squashfs|sysfs|tracefs)$”
# drop extensive scrape statistics
metric_relabel_configs:
- action: drop
regex: node_scrape_collector_.+
source_labels: [name]
relabel_configs:
- replacement: testvm01
target_label: instance
prometheus_remote_write:
- basic_auth:
password: 12521521
username: 12521521
url: http://prometheus:9090/api/v1/write
agent:
enabled: true
relabel_configs:- action: replace
source_labels:- agent_hostname
- agent_hostname
- action: replace
target_label: job
replacement: “integrations/agent-check”
metric_relabel_configs: - action: keep
regex: (prometheus_target_.|prometheus_sd_discovered_targets|agent_build.|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:- name
- action: replace
logs:
configs:
- clients:
url: http://promtail:3100/loki/api/v1/push
positions:
filename: /tmp/positions.yaml
scrape_configs: -
job_name: integrations/node_exporter_journal_scrape
journal:
max_age: 24h
labels:
instance: testvm01
job: integrations/node_exporter
relabel_configs:- source_labels: [‘__journal__systemd_unit’]
target_label: ‘unit’ - source_labels: [‘__journal__boot_id’]
target_label: ‘boot_id’ - source_labels: [‘__journal__transport’]
target_label: ‘transport’ - source_labels: [‘__journal_priority_keyword’]
target_label: ‘level’
job_name: integrations/node_exporter_direct_scrape
static_configs:- targets:
- localhost
labels:
instance: testvm01
path: /var/log/{syslog,messages}
metrics:
configs:
- localhost
- targets:
- name: integrations
remote_write:- basic_auth:
password: 12521521
username: 12521521
scrape_configs:
- basic_auth:
global:
scrape_interval: 60s
Promtail configmap
server:
http_listen_port: 9080
positions:
clients:
- url: http://loki:3100/loki/api/v1/push
external_labels:
job: promtail
Blockquote
No -
Create a config file | Grafana Agent documentation
