Grafana Cloud -
The CloudWatch metrics integration scrapes on a 5 minute interval by default, and I want to reduce this to avoid extra AWS costs. -
I’m trying to change it at Grafana -
What happened?
The dropdown only shows 1 option, and if I try to type manually (e.g.60m
) it says “Unable to load scrape intervals.”
