Hello
In Nagios XI, I have a service called w3c…The check is to check if it is running or not.
In Grafana, I want to consult it and show when it is running or now.
Hello
Is there a nagios plugin or does nagios offer a rest API?
Nagios is using NCPA to consult the Windows agent and that gives the info back.
Nagios also has a REST API that returns JSON
I would try the rest API approach with infinity plugin
