- Grafana version: 7.4.2
- Data source type & version:
- OS Grafana is installed on: Mac OS using home brew
- User OS & Browser: Big Sur & [Chrome, Firefox]
- Grafana plugins: n/a
- Others:
Create a Grafana plugin that uses React Router Dom -
Create a panel plugin and adding react router Dom -
What happened?
I created a simple panel app in Grafana that uses react-router-dom following the basic example on the react-router-dom website.
Also using Memory Router to hide the routes from the path so it does not conflict with Grafana.
However the plugin does not load in Grafana and it show the error: GET community.grafana.com/public/react-router-dom?_cache=1647427969793
HTTP/1.1 404 Not Found 5ms
i am using these packages
“@types/react-dom”: “^17.0.13”,
“@types/react-router-dom”: “^5.3.3”,
“react-dom”: “^17.0.2”,
“react-router-dom”: “^5.3.0”,
“react-scripts-ts”: “^3.1.0”
The plugin should have loaded without ant errors. -
There is no specific configuration. -
HTTP/1.1 404 Not Found 5ms -
Yes.
