Quick lock/edit mode of dashboards for tablet view
I would like to request a feature to make dashboards have a quick toggle readonly mode.
It is near impossible to scroll on a dashboard on a phone or tablet without moving around a panel. The readonly mode for a dashboard is there, it just isn’t readily available.
    IOS 15.4.1
    I’m trying to scroll a dashboard, but it is very difficult not to move a panel around when doing so.
    I place my finger in the small gap between panels and drag.
  • What happened?
    I moved a panel
    To move the dashboard view reference
    N/A
    N/A
It is possible to make a dashboard read-only, in order to better browse the dashboard on a tablet or phone, but I then have to toggle the configuration whenever I need to make a change.
I also have the option to access the grafana using a viewer only role, then would prevent me from editing and moving panels, but I am accessing Grafana using SSO, so my user cannot change.
Hi @machrisdk,
Welcome to :grafana: Community!
To ask for a new feature you should go to Github to open a discussion and if you have any problems in doing it then let us know.
Thanks!
So, what is the proper way of doing this?
