HI,
When using ElasticSearch Datasource, I can’t change the Data Histogram group by field. I can only use the Datasource default.
I want to have Query A using for example @timestamp and Query B the update time.
Regards
HI,
Regards
This is a limitation right now as the same field is used for date range filtering and histogram
