Grafana v7.3.3 - Amazon Instance -
We’re looking to graph an area chart with data coming from Elasticsearch. The x axis should be a group by of an integer field and the y axis an average of another numeric field. -
Using the Graph vizualisation. The query is using a “Group By” “Histogram” using the desired field. We’ve also tried changing the X Axis mode from “Time series” to “Histogram” to no avail. -
What happened?
When changing the group by on the queries from data histogram to histogram the graph shows “Unable to graph data”. -
The x axis to become the histogram value or able to be mapped to the value and the y value become the average metric. -
A
Query
Lucene query
Alias
Frame Time
Metric
Average
data.FrameTime
Options
Group by
Histogram
data.iterator
Interval: 1, Min Doc Count: 1 -
“Unable to graph data”. And a button to “Switch to table view”. -
N/A
Welcome,
Please provide a sample es document minus with obfuscated sensitive data points?
for example.
"_index": "edwards_the_great",
"_id": "uNU7xoEBhCIrnBmPJwlr",
"_version": 1,
"_score": 1,
"_source": {
"start": 1656603585607,
"end": 1656613809357,
"result": false,
"testRuns": [
"testEnvironment": null,
"totalSkipped": 0,
"totalFailed": 0,
"totalCount": 172,
"totalPassed": 172,
"totalFlaky": 0,
"flakyTests": {},
"failingTests": [],
"passed": true,
"stopOnFail": true,
"name": "Smoke Tests"
"testEnvironment": "SDK Environment",
"totalSkipped": 7,
"totalFailed": 2,
"totalCount": 47,
"totalPassed": 40,
"totalFlaky": 3,
"flakyTests": {
"flaky1/": 1,
"flaky2/": 1,
"flaky3/": 1
"failingTests": [
"failed1/",
"failed2/"
"passed": false,
"stopOnFail": true,
"name": "Sanity"
Hello yosiasz,
Thank you for your assistance. Unfortunately I don’t have access to the ES instance directly so I’m unable to provide an example of a document.
I have however provided an example of the query/response I’m running below:
"request": {
"url": "api/datasources/proxy/135/_msearch?max_concurrent_shard_requests=5",
"method": "POST",
"data": "{\"search_type\":\"query_then_fetch\",\"ignore_unavailable\":true,\"index\":[\"2022-07-04-data\",\"2022-07-05-data\"]}\n{\"size\":0,\"query\":{\"bool\":{\"filter\":[{\"range\":{\"timestamp\":{\"gte\":1656925423740,\"lte\":1657011823740,\"format\":\"epoch_millis\"}}},{\"query_string\":{\"analyze_wildcard\":true,\"query\":\"data.iterator:<=10\"}}],\"must\":[{\"match_phrase\":{\"data.event_type\":{\"query\":\"event_type_name\"}}}]}},\"aggs\":{\"2\":{\"histogram\":{\"interval\":1,\"field\":\"data.iterator\",\"min_doc_count\":1},\"aggs\":{\"1\":{\"avg\":{\"field\":\"data.FrameTime\"}}}}}}\n",
"hideFromInspector": false
"response": {
"took": 3402,
"responses": [
"took": 3402,
"timed_out": false,
"_shards": {
"total": 2,
"successful": 2,
"skipped": 0,
"failed": 0
"hits": {
"total": {
"value": 66,
"relation": "eq"
"max_score": null,
"hits": []
"aggregations": {
"2": {
"buckets": [
"1": {
"value": 10.75475001335144
"key": 0,
"doc_count": 6
"1": {
"value": 74.81934833526611
"key": 1,
"doc_count": 6
"1": {
"value": 21.918816248575848
"key": 2,
"doc_count": 6
"1": {
"value": 21.583483060201008
"key": 3,
"doc_count": 6
"1": {
"value": 18.708183606465656
"key": 4,
"doc_count": 6
"1": {
"value": 17.885199864705402
"key": 5,
"doc_count": 6
"1": {
"value": 18.15591637293498
"key": 6,
"doc_count": 6
"1": {
"value": 18.47748343149821
"key": 7,
"doc_count": 6
"1": {
"value": 18.19325002034505
"key": 8,
"doc_count": 6
"1": {
"value": 24.496050357818604
"key": 9,
"doc_count": 6
"1": {
"value": 22.333066781361897
"key": 10,
"doc_count": 6
"status": 200
"$$config": {
"method": "POST",
