Would it be possible to base (X-axis) a graph panel on a elastic doc’ Date other than the @timestamp?
Or how might I bucketize documents based on a Date like my signature_updated with these documents?
Maybe hints on howto do something like split series with in Kibana:
jlau
2
I think you have to make a new Data Source with ‘Time field name’ as signature_update.
And than use this new data source in your panel.
Ok, this may work. But howto possible to something like splitting/sub aggregating like in KIbana then?
jlau
4
Here is an example for not time histogram. Not sure if it will help you for date histogram.
You always can split up results with new terms:
To deal with the column colors, you have to play around with regex color settings
I am not sure, if a staple plot is possible.
@jlau Thanks that I’m familiar with, only I seemed to fail in doing this with my date fields, will have another look into this later…
