What are you trying to achieve? Create alerts for thresholds exceeded for CPU Utilization per process on linux server (multi-core cpu) using process_exporter
How are you trying to achieve it? Tried to write a PROMQL Query using namedprocess_namegroup_cpu_seconds_total
What happened? Unable to write a query successfully.
Did you follow any online instructions? If so, what is the URL? Could not find many resources on the topic.
can you share more about your metric? Is this metric namedprocess_namegroup_cpu_seconds_total what you should be using? With NodeExporter you would use something like:
sum(rate(cpu_seconds_total{}[5m])) by (instance)
so I guess you could use something like:
sum(rate(namedprocess_namegroup_cpu_seconds_total[5m])) by (process_name)
if you have process_name label?
This is for process exporter not node exporter
if you haveprocess_namelabel?’
Without any more info it will be hard to tell - do you have a label that represents the process name? I guess the method doesn’t change because the metric name and gathering isn’t changed either.
Have you tried adjusting the query to use rate named process name group CPU seconds total [1m] for CPU usage per process? That should help smooth out the data over time for better alerts.
