I’m trying to find a way to build a query in Grafana to get all records from Loki data source based on a custom variable I defined as follows -
- variable type: custom
- variable name: hidden_networks
- show on dashboard: label and value
- values separated by comma: 10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16
- multi-value: enabled
My very basic query currently looks like this:
{service_name="nginx"}
but what I’m trying to achieve is:
{service_name="nginx"} | json | remote_addr != ip("${hidden_networks}")
Unfortunately this doesn’t work, because the ‘ip’ function takes only one argument and the dashboard variable is configured as multi-value. If I disable multi-value functionality on the hidden_networks
variable, everything is working as expected, but I need ability to select multiple CIDR networks and hide them from logs.
Is there a way to ‘unpack’ the list of values in a multi-value variable and add a dedicated | remote_addr != ip(xxx)
to the query for each value individually?
