cembol
1
I’ve made a dashboard which ping to the devices. create instance variables so I can get devices ip’s.
when I setup dashboard with variables it returned 0 row from query.
if I edit the code line with certain ip of a devices query returns with results.
I did this config a while ago and it was working. what is wrong here?
yosiasz
2
What is the \\ in the ip address, is that how the data is saved? That might be your issue. The regex on your variable might have an issue?
cembol
3
as you mentioned, yes that is the problem. I used regex to ignore intances that don’t have ip like localhost. so I need to use regex match.
thank you.
