Prometheus Variables Not Working
I am currently modifying a dashboard to work with my Prometheus data source. I put in the dashboard variables and the query returns what I am looking for:
However, when I try the variable in my visual I get no data:
If I enter the metric statically I get data:
Any ideas?
What does it look like when you click on Query Inspector?
It might be you need to use interpolation like ${host:csv}?
Check following out
The $hostname variable works just fine. I’ve tested it in Explore and the query inspector. The inspector comes back with no data on thee $cpu variable, yet it recognizes the variable:
In the dashboard variable:
I figured it out. I needed to write me regex to include cpu-total
/cpu[0-9]|cpu-total/
