- Grafana v12.2.0-16895479002 (238961d3ea) on Ubuntu
- Getting the “max size value” of the disk that I am showing the percent of next to the name on the left of the server its from:
Hello!
I am pretty new to grafana and still figuring out how everything works, I mainly use it to monitor the windows physical and virtual Servers with the windows_exporter.
I got it working pretty okay, but I just cannot get this graph which shows all disks to not only show the percent used but what disk size itself is to begin with.
Thanks for the help in advance
Tatsu
