I follow the directions to setup prtg integration Setup but when I try to add a dashboard I get this
Any help would be appreciated.
Delete every “*”. if you have set up PRTG correctly you want to start from group and wait for the dropdown to populate. It may take a few seconds before it does. Start at group, then host, then sensor and finally channel
