I am trying to connect Grafana to PRTG.
I installed the “neural fraud” plug in, and I can see the data source under “connections > data sources”.
When I choose the data source and click “save & test” then it says “data source updated”, and when I click “explore” then I see the groups, sensors etc, I can see the “run query” button and can create graphs.
However, when I go to the dashboard, create a new visualization and try to create a query then I don’t see the correct groups, sensors etc. also, I don’t have the “run query” button.
Has anyone run into this issue before? How did you fix it?
I use Grafana v9.5.1.
