Proxy Erro to access Grafana
Hello everyone,
I have installed Zabbix on my server running on a DNS and HTTPS, I installed on the same server as Grafana and I want to configure it to be accessed through the url: mydomain.com/grafica but I am having the following message: The proxy server received an invalid response from an upstream server.
The proxy server could not handle the request GET / grafana.
Grafana.ini:
[server]
Protocol (http, https, socket)
protocol = https
The ip address to bind to, empty will bind to all interfaces
; http_addr =
The http port to use
#http_port = 3000
The public domain name used to access grafana from a browser
; domain = localhost
Redirect to correct domain if host header does not match domain
Prevents DNS rebinding attacks
; enforce_domain = false
The full public facing url you use in browser, used for redirects and emails
If you use reverse proxy and sub path specify full url (with sub path)
; root_url = http: // localhost: 3000
Virtual Host:
    ProxyPreserveHost On
    ProxyPass / grafana http: // localhost: 3000
    ProxyPassReverse / grafana http: // localhost: 3000
Can anybody help me?
