Long and short of it is I am trying to use a prebuilt Proxmox dashboard, but none of the servers are showing up. I’ve tried change variables, to different configs to see what would happen. But the really frustrating part is when I run the query in explore, it works. Screenshots below, coming from InfluxDB,
I’ve been at this for about 5 hours now and none of it makes sense.
Grafana v11.1.0 (5b85c4c2fc), running on docker
Get my dashboard to output the “server” variable -
I have tried manually running the query in the explore tab, which works, but it does not out put anything the dashboard when its run -
What happened?
When run manually, it outputs _value, and my server name, when run in the dashboard query editor, it outputs “None” or “All” if multiple output is selected -
Output my servername -
from(bucket: “${Bucket}”)
|> filter(fn: (r) =>
r._measurement == “system” and
r.object == “nodes”
|> keyValues(keyColumns: [“host”])
|> group()
|> keep(columns: [“host”])
|> distinct(column: “host”)
No errors with the IU
