Hello there!
First off, apologies if this landed in the wrong category - I went up and down the list but was not sure where exactly to put this…
Basically, I am kinda, sorta, slightly poked by my collegues about a few of Grafana’s behaviours once in a while and end up writing some Github issues - depending on if I can solve it on my own or get stuck or upright find a bug. This time, it is the latter; at least from everything I can tell: Provisioning: Paths in folders appear duplicated · Issue #91826 · grafana/grafana · GitHub
What is the proper way of escalating things? I don’t want to be a nuisance, but I also want to find my way to a solution or make sure that a legitimate bug report is seen. So hence why I wanted to ask: How to do this correctly and properly?
The TL;DR of the bug/issue I found is that provisioned dashboard paths containing a slash are created twice - one empty, one not. I checked the documentation but could not find anything about naming restrictions for folders, so I assume slashes in folder names are alright. That said, I am visually impaired, I wouldn’t rule out that I legit just overlooked something - wouldn’t be the first time this happened. ![]()
Thank you very much and kind regards
