This is my yaml file for promtail:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://loki:3100/loki/api/v1/push
scrape_configs:
- job_name: system
pipeline_stages:
# Written by Gemini
- regex:
expression: '(?P<timestamp>\d{4}-\d{2}-\d{2}T\d{2}:\d{2}:\d{2}.\d+)\+\d{2}:\d{2}) (?P<host>\S+) (?P<severity>\S+),(?P<message>.+)'
timestamp:
type: timestamp
host:
type: string
severity:
type: string
message:
type: string
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/{messages,kern}.log
- job_name: docker
pipeline_stages:
- docker:
static_configs:
- targets:
- localhost
labels:
job: docker
__path__: /var/log/docker.log
What I’m trying to do is run different pipeline stages on different log files as they have different formats. Unfortunately Promtail doesn’t like it and responds like this:
promtail-1 | level=info ts=2024-11-09T09:28:17.044338977Z caller=promtail.go:133 msg="Reloading configuration file" md5sum=2f477bea549d6246df9274f9e6e9eaa3
promtail-1 | level=error ts=2024-11-09T09:28:17.045242906Z caller=main.go:169 msg="error creating promtail" error="failed to make file target manager: pipeline stage must contain only one key"
promtail-1 exited with code 1
I can’t understand where the problem is here. Can anyone help?
Thanks in advance! ![]()
