Hi everyone, I am currently configuring promtail to receive log from Nginx, mysql, system but it doesn’t work, promtail.yml file information as below, error level=error ts=2023-05-19T19:08:50.715608519Z caller=main.go:170 msg=“error creating promtail” erro r=“failed to make file target manager: pipeline stage must contain only one key” from the reporting container.
promtail.yml
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients: #khai báo link để log từ promtail push tới
scrape_configs:
job_name: Log_VPS
static_configs:-
targets:
- localhost
labels:
job: Logs_Nginx
host: VPS
agent: Log_Nginx
path: /var/log/nginx/*log
- localhost
targets:
- localhost
labels:
job: Log_Mysql
host: VPS_mysql
agent: Log_Mysql
path: /var/log/mysql/*log
- localhost
targets:
- localhost
labels:
job: Logs_system
host: system
agent: Log_system
path: /var/log/*log
- localhost
pipeline_stages:
- json:
expressions:
http_user_agent:
request_uri: - drop:
source: http_user_agent
expression: “(bot|Bot|RSS|Producer|Expanse|spider|crawler|Crawler|Inspect|test)” - drop:
source: request_uri
expression: “/(assets|img)/” - drop:
source: request_uri
expression: “/(robots.txt|favicon.ico|index.php)” - drop:
source: request_uri
expression: “(.php|.xml|.png)$”
docker-compose.yml
version: ‘3.8’
networks:
monitoring:
driver: bridge
volumes:
prometheus_data: {}
grafana_data: {}
grafana-logs: {}
services:
node-exporter:
image: prom/node-exporter
container_name: node-exporter
restart: unless-stopped
volumes:
- /proc:/host/proc:ro
- /sys:/host/sys:ro
- /:/rootfs:ro
command:
- ‘–path.procfs=/host/proc’
- ‘–path.rootfs=/rootfs’
- ‘–path.sysfs=/host/sys’
- ‘–collector.filesystem.mount-points-exclude=^/(sys|proc|dev|host|etc)($$|/)’
ports:
- “9100:9100”
expose:
- 9100
networks:
- monitoring
prometheus:
image: prom/prometheus
container_name: prometheus
volumes:
- ./config/prometheus.yml:/etc/prometheus/prometheus.yml
- prometheus_data:/prometheus
command:
- ‘–config.file=/etc/prometheus/prometheus.yml’
- ‘–storage.tsdb.path=/prometheus’
- ‘–web.console.libraries=/etc/prometheus/console_libraries’
- ‘–web.console.templates=/etc/prometheus/consoles’
- ‘–web.enable-lifecycle’
ports:
- “9090:9090”
expose:
- 9090
networks:
- monitoring
grafana:
image: grafana/grafana:latest
container_name: grafana
volumes:
- grafana_data:/var/lib/grafana
- ./config/datasource.yml:/etc/grafana/provisioning/datasources/datasource.yml
ports:
- "3000:3000"
networks:
- monitoring
#Loki-Promtail (Log)
promtail:
image: grafana/promtail
restart: always
container_name: promtail
volumes:
- ./loki/promtail.yml:/etc/promtail/config.yml
- /var/log:/var/log
- /var/log/mysql:/var/log/mysql
- /var/log/nginx:/var/log/nginx
entrypoint:
- /usr/bin/promtail
- -config.file=/etc/promtail/config.yml
ports:
- “9080:9080”
networks:
- monitoring
loki:
container_name: loki
image: grafana/loki
restart: always
volumes:
- ./loki/data:/loki
- ./loki/loki.yml:/etc/loki/local-config.yaml
entrypoint:
- /usr/bin/loki
- -config.file=/etc/loki/local-config.yaml
ports:
- “3100:3100”
networks:
- monitoring
