An issue with promtail
When I use the following configuration file:
apiVersion: v1
kind: ConfigMap
metadata:
namespace: trainee-playground-1
data:
config.yml: |
server:
http_listen_port: 9080
grpc_listen_port: 0
log_level: debug
clients:
  - url: http://loki:3100/loki/api/v1/push
positions:
  filename: /tmp/positions.yaml
scrape_configs:
- job_name: pod-logs
  kubernetes_sd_configs:
    - role: **pod**
      namespaces:
        names:
          - trainee-playground-1
I cannot see any targets on the loki api.
but when i use
apiVersion: v1
kind: ConfigMap
metadata:
data:
config.yml: |
server:
grpc_listen_port: 0
log_level: debug
clients:
positions:
scrape_configs:
    - role: **service**
      namespaces:
        names:
i can see 12 services, why is that? on the logs I don’t see anything different, just not the part of new target found
Just decided to run a promtail container inside every pod and read directly the data there
:grinning_face:
