Loki is ready, and I can connect, but I cannot list logs in Loki Grafana. The Promtail target readiness is also ‘False’.
What should I change ?
docker-compose.yml
promtail:
image: grafana/promtail:2.6.1
ports:
- “9080:9080”
volumes: - ./promtail-config.yaml:/etc/promtail/config.yaml
- /var/log:/var/log
- /var/lib/docker/containers:/var/lib/docker/containers
- /var/run/docker.sock:/var/run/docker.sock
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
scrape_configs:
- job_name: system
static_configs:- targets:
- localhost
labels:
job: varlogs
path: /var/log/*log
- localhost
- targets:
