Promtail can not push log to loki
I use promtail to push my docker-compose’s log,but I meet a problem like this:
level=error ts=2023-05-11T01:38:37.421215001Z caller=client.go:430 component=client host=loki:3100 msg="final error sending batch" status=400 tenant= error="server returned HTTP status 400 Bad Request (400): error at least one label pair is required per stream"
It seems like my promtail configured Incorrectly.This is my config:
[root@tq-deploy tq_deploy]# cat loki/config.yml
server:
  http_listen_port: 9080
  grpc_listen_port: 0
positions:
  filename: /tmp/positions.yaml
clients:
  - url: http://loki:3100/loki/api/v1/push
scrape_configs:
  - job_name: system
    docker_sd_configs:
      - host: unix:///var/run/docker.sock
        refresh_interval: 5s
#    relabel_configs:
#      - source_labels: ['_meta_docker_container_name']
#        regex: '/(.*)'
#        target_label: 'container'
#        replacement: "$1"
#      - source_labels: ['__path__']
#        regex: '/var/log/(.*)'
#        target_label: 'job'
#        replacement: "$1"
I don’t know how can I push log to loki. My docker-compose use json-file to store log.
You have to have something in relabel_configs
Hi,this is my config
server:
  grpc_listen_port: 0
positions:
clients:
  #- url: http://loki:3100/loki/api/v1/push
  - url: http://loki:3100/api/prom/push
scrape_configs:
  - job_name: system
    docker_sd_configs:
    relabel_configs:
        regex: '/(.*)'
     #   replacement: "$1"
    #  - source_labels: ['__meta_docker_container_id']
    #    target_label: '__path__'
    #    replacement: '/var/lib/docker/containers/$1/*.log'
    pipeline_stages:
      - docker: {}
      - cri: {}
      - json:
          expressions:
            stream: stream
            log: log
      - static_labels:
          host: "tq"
and I can find default in promtail default label like ‘__meta_docker_container_id’,but I think promtail not send label to loki.
I am a newest of loki and I have no idea about my probelm.
Any label that starts with __ is either metadata or has some other special meaning. They will not be added as labels.
Your relabel_config should have a few actions like this
  relabel_configs:
      - action: replace
        source_labels:
          - __meta_something_you_want_as_a_label
        target_label: name_of_label_you_want_to_see_in_loki
Yes,I am a fool,I write _ as __,it not work. Now everything is ok. thank you!
I’m having a similar problem myself though I am getting the logs for promtail it is also sending logs like this
2023-11-02 20:42:09.555
trajano_promtail.ic4p6gb3jq91xmqv7cpyep8ij.qsmyx1it80x5lnnjmymouxdb4
stderr
level=error ts=2023-11-03T00:42:09.473271419Z caller=client.go:430 component=client host=loki:3100 msg=“final error sending batch” status=400 tenant= error=“server returned HTTP status 400 Bad Request (400): error at least one label pair is required per stream”
Fields
container_name trajano_promtail.ic4p6gb3jq91xmqv7cpyep8ij.qsmyx1it80x5lnnjmymouxdb4
stream stderr
My config file scrape config looks like this
scrape_configs:
  - job_name: docker
    docker_sd_configs:
        filters:
          - name: label
            values: [ "com.docker.swarm.task" ]
    relabel_configs:
      - source_labels: [__meta_docker_container_log_stream]
        target_label: stream
      - source_labels: [__meta_docker_container_name]
        regex: ''
        action: drop
        regex: '/(.*)'
        target_label: container_name
      - source_labels: [__meta_docker_container_label_promtail_enabled]
        regex: "false"
        action: drop
So I am getting the replacement but some messages are causing a problem. So I tried to do the drop when __meta_docker_container_name is '' along with a label check
Turning on debug log didn’t help much since it didn’t tell me what message or log entry it sent that causes the issue.
Hi, I’m having the exactly same issue with a very similar config:
      docker_sd_configs:
      pipeline_stages:
      relabel_configs:
      - source_labels: ['__meta_docker_container_label_grafana_logging_disable']
        regex: 'true'
        action: drop
This causes the same error:
level=error ts=2024-01-29T14:31:18.460915591Z caller=manager.go:49 component=distributor path=write insight=true msg="write operation failed" details="error at least one label pair is required per stream"
It does not happen when I remove this bit:
        regex: 'true'
        action: drop
Have you found a solution for this?
Does anybody know whether there any way to drop logs only if a label has a certain value?
Okay, turns out the fix was to simply add a static label like so in pipeline_stages instead of adding it in relabel_configs:
- static_labels:
    instance: '<...>'
I don’t quite understand why a dropped log requires a label though.
In order to filter containers by their labels, just apply a filter like this:
docker_sd_configs:
        refresh_interval: 60s
        filters:
          - name: label
            values: ["promtail.enable=true"]
Static labels work well for static (well, obviously) labels that would be great to add. For example, in my current configuration I add hostname so that in grafana I can filter by this label:
pipeline_stages:
      - static_labels:
            node_hostname: "${HOST_HOSTNAME}"
Full Scrape Configs:
scrape_configs:
  - job_name: containers
    docker_sd_configs:
        filters:
          - name: label
    relabel_configs:
    pipeline_stages:
      - static_labels:
      - docker: {}
      - timestamp:
          format: RFC3339Nano
          source: time
      - labels:
          stream:
          container_id:
      - output:
          source: log
