I’m trying to get Promtail 2.5 running on Cumulus 4.1 (Debian 4.9.2) Linux version 4.1.0-cl-7-amd64.
If I start Promtail with this config:
server:
disable: true
clients:
- url: http://loki:3100/loki/api/v1/push
positions:
filename: /opt/promtail/positions.yaml
scrape_configs:
- job_name: journal
journal:
json: false
max_age: 12h
labels:
job: systemd-journal
relabel_configs:
- source_labels: ["__journal__systemd_unit"]
target_label: "unit"
- source_labels: ["__journal__hostname"]
target_label: "hostname"
I get the following error: cannot allocate memory for thread-local data: ABORT
free -h
total used free shared buffers cached
Mem: 1.9G 1.1G 817M 40M 876K 727M
-/+ buffers/cache: 366M 1.5G
Swap: 0B 0B 0B
Swap is disabled, does promtail need the swap to be enabled?
If I remove the scrape config or point it to an empty file, promtail will start without error. It seems this is only happening if it’s trying to scrape the systemd journal.
Initially I got this error:
./promtail-linux-amd64 -config.file=./promtail_config.yaml
level=info ts=2022-07-05T20:20:38.109078844Z caller=main.go:119 msg=“Starting Promtail” version=“(version=2.5.0, branch=HEAD, revision=2d9d0ee23)”
runtime/cgo: out of memory in thread_start
After trying to run it a few times it would only show the error I mention above.
Any ideas? Thoughts on how I can dig into this more?
