Promtail config
    8.5.3 / Linux
    Wanted to know of there are configs available to stop promtail process by itself or restart after a particular time
    I’m trying to ingest around 10gb data at a single run, where i’m getting too many open files error, error sending batch. While these errors were fixed by increasing the limits in loki.yaml. But now i’m seeing inotify resources exhausted, inotify cannot be used, reverting to polling errors and data is not reaching loki.
    loki configs
server:
  http_listen_port: 3100
  grpc_listen_port: 9096
common:
  path_prefix: /tmp/loki
  storage:
    filesystem:
      chunks_directory: /home/oracle/elasticsearch/loki/chunks
      rules_directory: /home/oracle/elasticsearch/loki/rules
  replication_factor: 1
  ring:
    instance_addr: <ip>
    kvstore:
      store: inmemory
ingester:
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
    final_sleep: 0s
  chunk_idle_period: 5m
  chunk_retain_period: 30s
  max_transfer_retries: 0
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
ruler:
  alertmanager_url: http://<ip>:9093
limits_config:
  enforce_metric_name: false
  reject_old_samples: false
  #reject_old_samples_max_age:
  ingestion_rate_mb: 10240
  ingestion_burst_size_mb: 5120
  per_stream_rate_limit: 2560MB
chunk_store_config:
  max_look_back_period: 0s
table_manager:
  retention_deletes_enabled: false
  retention_period: 0s
promtail configs
    http_listen_port: 9080
    grpc_listen_port: 0
positions:
  filename: /tmp/positions.yaml
clients:
  - url: http://<ip>:3100/loki/api/v1/push
scrape_configs:
    #APPLICATION LOGS
- job_name: APPLICATION
  static_configs:
  - targets:
      - <ip>
  - labels:
      log_type: APPLICATION
      component_type: all_server_logs
      __path__: "/home/oracle/catt-logs-week23/**/{*.log,*.log*}/*"
