Hello everyone, first post as I am trying to build an IDS panel leveraging on-prem (no i wont pay for the cloud, ever) grafana + loki + promtail + snort3
I have all of these working BUT promtail because it just loops and chokes itself to death
VM hosted on Proxmox VE w/ 4 cpu’s and 24GB of vRAM
Version:
promtail, version 2.8.2 (branch: HEAD, revision: 9f809eda7)
build user: root@b7e9ca0bf6e0
build date: 2023-05-03T11:13:57Z
go version: go1.20.4
platform: linux/amd64
The Issue:
- Regardless if its 8GB, 64GB of RAM, as soon as the promtail service starts, the leaks/runs away until complete lockup (under 20 seconds)
What have I tried:
- Different vCPU (now on host cpu, EPYC 7551P, which has AVX2 encoding, to be safe)
- Different RAM
- Various bandwidth limits in the .yaml file (no change in end result)
Current Configs:
- Promtail .service file
[Unit]
Description=Promtail Service
After=network.target
[Service]
Type=simple
User=promtail
ExecStart=/opt/loki/promtail-linux-amd64 -config.file=/opt/loki/promtail-local-config.yaml
[Install]
WantedBy=multi-user.target
- Current YAML file for Promtails
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://localhost:3100/loki/api/v1/push
limits_config:
readline_rate_enabled: true
readline_rate: 10
readline_burst: 20
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/*log
Just for reference:
- Current Loki YAML file
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
- All the other services
user@host:/opt/opensearch$ systemctl status snort3
● snort3.service - Snort Daemon
Loaded: loaded (/etc/systemd/system/snort3.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-07-06 23:43:59 EDT; 43min ago
Main PID: 636 (snort)
Tasks: 2 (limit: 28769)
Memory: 295.5M
CPU: 33.325s
CGroup: /system.slice/snort3.service
└─636 /usr/local/bin/snort -c /usr/local/etc/snort/snort.lua -s 65535 -k none -l /var/log/snort -D -i ens18 -m 0x1b -u snort ->
user@host:/opt/opensearch$ systemctl status grafana-server.service
● grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-07-06 23:44:02 EDT; 43min ago
Docs: http://docs.grafana.org
Main PID: 890 (grafana)
Tasks: 20 (limit: 28769)
Memory: 172.6M
CPU: 5.336s
CGroup: /system.slice/grafana-server.service
└─890 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --pack>
user@host:/opt/opensearch$ systemctl status loki.service
● loki.service - Loki logging daemon
Loaded: loaded (/etc/systemd/system/loki.service; enabled; preset: enabled)
Main PID: 632 (loki-linux-amd6)
Tasks: 9 (limit: 28769)
Memory: 93.5M
CPU: 5.291s
CGroup: /system.slice/loki.service
└─632 /opt/loki/loki-linux-amd64 -config.file=/opt/loki/loki-local-config.yaml
Thank you for your time,
Scott
