PromQL Warning for Custom Metric Name – Inconsistent Behavior Across Grafana and Prometheus Versions
Hello team,
I’m using a Grafana dashboard with Prometheus as the underlying data source. For some PromQL queries, I’m seeing an unwanted warning message:
`PromQL info: Metric might not be a counter — name does not end in _total, _sum, or _bucket: custom_random_gauge`
I would like to understand how to permanently suppress or eliminate this warning.
this is how warning looks like
To reproduce this issue, I created a minimal Spring Boot application that exposes a custom gauge metric (custom_random_gauge). I ran this locally and tested with different combinations of Grafana and Prometheus versions.
Here’s a summary of my observations:
Column 1 Column 2 Column 3 Column 4
Prometheus Version Grafana 10.4.2 Grafana 11.4.0 Grafana 12.0.2
2.52.0 Warning shown Warning shown Warning shown
2.55.1 Warning gone Warning gone Warning shown
3.5.0 (latest) Warning gone Warning gone Warning shown
I also found this GitHub issue that appears to be related:
https://github.com/grafana/grafana/issues/84636
My Question
Could someone from the team please clarify:
  • Why does this warning appear only for specific combinations of Prometheus and Grafana versions?
  • Is this behavior expected or a regression?
  • Is there a recommended way to disable this warning for custom metrics that do not follow the _total, _sum, or _bucket naming convention?
  • Can a future upgrade reintroduce the warning even if it’s currently not shown?
Since our applications may be upgraded independently of Prometheus/Grafana, we want to ensure that the warning doesn’t unexpectedly return in future deployments.
Thanks in advance for your help and clarification.
