I have setup Prometheus and Grafana for monitoring my kubernetes cluster and everything works fine. Then I have created custom dashboard in Grafana for my application.The metrics available in Prometheus is as follows and i have added the same in grafana as metrics:
sum(irate(container_cpu_usage_seconds_total{namespace=“test”, pod_name=“my-app-65c7d6576b-5pgjq”, container_name!=“POD”}[1m])) by (container_name)
The issue is, my application is running as pod in kubernetes,so when the pod is deleted or recreated, then the name of the pod will change and it will be different than the pod name specified in the above metrics “my-app-65c7d6576b-5pgjq”. So the data for the above metrics will not work anymore. and I have to add new metrics again in Grafana. Please let me know How can I overcome this situation.
