PROMQL query to instance group metrics
    Grafana Enterprise , in conjunction with gcp instance group and Google GMP
    Have the following query for instances within an instance group . however every time we update instances …new instances are created …so no visibility to historical data for terminated instances. This data is within the monarch db , and perhaps can be queried . How is the big question ?
    Have this existing query :
    sum by (instance, name)(rate(tfe_container_cpu_usage_kernel_ns{instance=“$node”,run_type=“”}[$rangeinterval]) + rate(tfe_container_cpu_usage_user_ns{instance=“$node”,run_type=“”}[$rangeinterval])) / 1e7)
  • What happened?
    Need to find a way to query the instance group metrics from monarch db
    sum by (instance, name)((rate(tfe_container_cpu_usage_kernel_ns{instance=“$node”,run_type=“”}[$rangeinterval]) + rate(tfe_container_cpu_usage_user_ns{instance=“$node”,run_type=“”}[$rangeinterval])) / 1e7)
No since the instance group names change , we missing historic data for terminated instances .
    n/a.
