Version 9.1.0 and CentOS Linux release 7.9.2009 (Core -
Start Prometheus Service -
systemctl start prometheus.service -
What happened?
prometheus services was working fine before but suddenly it stopped -
prometheus service should be working fine with all the older past history data as well. -
-NA -
Dec 19 05:56:25 hostname prometheus[43047]: level=info ts=2022-12-19T12:56:25.246320733Z caller=repair.go:48 component=tsdb msg=“found healthy block” mint=1670875200000 maxt=1670882400000 ulid=01GMA7GZYSF3Q5F9A8NGZ6TYV9 -
We did not get any relevant links
