Dear all I am new to prometheus and grafana, I have some question that confused me more than half month.
I have running an application call erigon - a eth wallet node. I want eanble the prometheus with granfana to monitoring it status of running.
but while I install prometheus with granfana there is issue occurs below, thank you so much.
(by the instruction erigon/Readme.md at devel · ledgerwatch/erigon · GitHub
System information
Erigon version: v2022.07.03
OS & Version: Linux Debian 11
I have run erigon by ./build/bin/erigon --metrics.addr
and compose up -d prometheus grafana by defualt prometheus.yml configuration file and able to see these 2 dockers is up but unable to access it from ip:3000 or ip:9090, also there is warning message occurs after docker compose
[+] Running 1/2 ⠿ Container erigon-grafana-1 Started 1.9s ⠿ Container erigon-prometheus-1 Starting 1.9s Error response from daemon: driver failed programming external connectivity on endpoint erigon-prometheus-1 (1b8ae6e197f2d2dfb4f8bb389091af06102c076763ed8e75685ebee125cc88ed): Error starting userland proxy: listen tcp4 0.0.0.0:9090: bind: address already in use
is there someone can help to answer or give some hints to running prometheus properly?
