hi,
i want to create a influxdb2, telegraf and grafana server (integra). influxdb and telegraf installation works fine.
The grafana installation went wrong with the service.
Proxmox CT Container with Debian 11.x.
Partition 8gb, Ram 1024, 2 cpus
Installation from this side:
grafanasite
Grafana standard no enterprise.
Grafana.ini set level to debug but no changes.
I am able to reset the container to Installation without grafana. (Snapshot)
I also read a few topis here ,but without any solution.
error message:
root@Integra:/etc/grafana# systemctl status grafana-server
* grafana-server.service - Grafana instance
Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2023-08-25 07:22:01 UTC; 5s ago
Docs: http://docs.grafana.org
Process: 922 ExecStart=/usr/share/grafana/bin/grafana server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafana-server.pid --packaging=deb cfg:default.paths.logs>
Main PID: 922 (code=exited, status=226/NAMESPACE)
Aug 25 07:22:01 Integra systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at 5.
Aug 25 07:22:01 Integra systemd[1]: Stopped Grafana instance.
Aug 25 07:22:01 Integra systemd[1]: grafana-server.service: Start request repeated too quickly.
Aug 25 07:22:01 Integra systemd[1]: grafana-server.service: Failed with result 'exit-code'.
Aug 25 07:22:01 Integra systemd[1]: Failed to start Grafana instance.
any ideas?
Regards Alero
